marcof
you are doing the smart and out of the question!
I wrote "in a purely academic discussion", that scheme at the beginning of the thread, with a flywheel on the shaft led and started at 90° (but perhaps even a little less, depending on the mass of the flywheel) from the dead point puts in continuous rotation the shaft led or not?
I'm going to make wood to start the crusher... :tongue:
Surely not.
Maybe a few rounds can make it, but only by chance and only if the cranks are of equal measure, not as in the scheme of the theme.
the discussion developed in this direction:Let's throw it like that...
in theory yes..
in practice, you do it only if you spot it at pms outdated and if inertia is such as to make sure that the shaft led passes alone the pmi.
data:
with two hand cranks of equal measure (like those of locomotives) assess the possibility, in a completely academic way, that system functions with continuous motion of the wheel conducted, starting far from the dead point and with flying on the wheel conducted.
(my) :
I say that if the sizing of the flywheel, the distance of the handle of the center and sufficiently large the assembly is sufficiently precise the acrocco works and once party does not incarnate passing to the alternating motion.
do not pull me out again different cranks (stefanobruno) and starters at the dead point (bmt) otherwise the academic discussion is no longer fun. :wink:
