help! how to use match shape function?
  • Thread starter Thread starter User1
User1
Having an open profile I want to use the extrude command, but at the time when I activate the solid output, select the open profile and automatically activate the match shape function, but after I can't continue!:confused: could you please explain to me how to use this command?
If you have an open profile, it can't create a solid, but it can only make an extrusion of surface (supply for the Italian inventor)
if you want to give a thickness to the supestrusion, or use the "extension" command or use the "contour flange" command in sheet metal environment
If you want to use it you must have at least another solid workmanship or delimitation plans for open sketch extensions prior to that.
If you click on the button below to the left of the extrude command window opens the guide where it explains you as an aunt.
I also believed, I don't know exactly since, but at least in 2010 you can do it.
