elmatador83
Hi, excuse me if I'm breaking some rules but I'm new to the forum.I looked for the answer to my question in the discussions (both blessed the search button) but I didn't find it.for the thesis I'm using the hypermesh sw with user's profile nastran, the analysis takes place on a sandwich structure, the problem is once modeled the core with solid elements I should shape the two skins with pshell elements (cquad4) as I do. I used the option, in the properties of the components, cont activating z1-z2 and setting the thickness (default is set with z1=-t/2;z2=t/2), and with zoff (offset on the individual elemnti), but when I check the interconnection with different tests I realize that nn activates the commands and continues to develop the thickness from the midsurface.
Thank you for your help :finger:
greetings savior:smile:
