help in the first calculations? ? ?
  • Thread starter Thread starter Teo_op
Teo_op
hello to all, to make it short I am doing a three-year thesis in the hydraulic field and I was asked for a cdf analysis by means of simulation flow of solidworks of a three mouth valve (an aspiration and two sent). the program turns correctly and also the "fluid volume" is calculated correctly. during the analysis I met these problems:
1# I should insert on some surfaces of the "equation goals" but I am not very clear the procedure that describes the program's help.
2# I would need to change the pressure or flow to one of the two outlet vents but clicking on the appropriate button to insert a function opens me a sort of calculator of which I do not find sufficient information on the help to be able to use it.
I know these are stupid questions but I don't come to the head:confused:! Thanks to anyone who wants to help me.
greetings, teo
