help pc very slow, possible configuration pc for inventor 2014?
  • Thread starter Thread starter Brethil
excluding the network, I can think of some software problem.
like, is it a long time that you don't format your computer? even my computer after 4 years of work did not even open autocad 2005lt. formatted returned to do his work.
your hardware configuration is not that it is monstrous, but not even a bowl, as confirms tarkus. so if you don't have big claims, your pc should work dignifiedly with inventor.
the pigs was formatted in June because before I had xp 64(ahahahahahah)bit, but when came inventor 2014 was conceived for win 7 as since 2014 winxp 64bit was no longer supported by microsoft.
inventor 2014 on xp64 I didn't even install it if I prayed in Babylonian axle.
planned the pigeon things went better...imagine first with inventor 2013 as I lived...
_
Raga, you hear the capraggine, but disable the famous and dark hyper-threading from bios could help me with something? ...I have four cores...
quoto!
hello, thank you and I confirm that they are the same drivers that I have installed...but the card remains cmq an old little performance
_
and your problem is the video card? :rolleyes:
I work again (I am forced) with creo 2.0, under windows xp 64 bit.
12 gb of ram, but it's like having 3.
If you try to search for certified drivers for this pair, you will notice that they are not there (and it seems obvious, talking about xp 64 bit).
force and courage brethil!! ! !
Could you post an image of the axieme you work on?
just to figure out if it's such a big deal to put the pc in trouble.
I passed to 2014 and now a 10000-part assembly, which on 2013 I put on the table in a few minutes, I stack the computer (frame envy 4000, 32gb ram, workstation hp z420: I refuse to think of an undersized machine!).
Does it happen to others?
I add that for assembling 100/200 parts everything works well and fast.
Good girl.
for now I seem to have solved many problems of fluidity especially in the table.. .
with 24gb ram you live better than with 6..inventor2014 travels from fear. .
in fact the ram at the max climbed on the 8.5gb of use in the task manager, during the putting in board of very substantial assemblies!
That's why he died with six!
the video card for now remains the old picture fx1800, which does not seem to go crazy much.
in the meantime thank you all
_
