help, saldature con inventor!
ALPHASIERRADELTA
hi, as already mentioned in the presentations, I've been using the inventor for a few weeks, already knowing the v5 I'm quite well in the search for commands, the only my problem for now are welding, I had to learn to use the inventor precisely for this reason, I created a welded assembly but when I use the weld command I can not physically position in the 3d weld, someone can give me some advice, better yet some procedure
Thank you all.
