help - separate single level base
  • Thread starter Thread starter spantik
spantik
Hello, everyone.
I tried to peek in the forum and it doesn't seem to have found an answer and then I ask below:
I have the need, to export to excel the distinction of a single-level machine, in order to have immediately the exact list of all the pieces, without having to be able to analyze them in all the sub-axis. I tried to use the window "only parts", but it only exports the pieces to the main level.
I hope I've explained decently.
thanks to all
but do you want the distinct monolevel structure or at all levels??
you can set both cases ..
I would like single level of all pieces, even as verification for orders. so I avoid forgetting pieces of the sub assemblies (more than anything for verification. I tried to single-level but only exports all parts of the main level, does not take into account the below levels
depends on how imposed "different structure components" of the axioms in question.
if they are set as "normal" or "inseparable", in separate only parts will appear to you only the assieme and not the parts it contains.
if instead a set is set as "hidden", the axieme does not appear and rise in level the parts contained in it and appear in "only parts".
personally, when I create a subaxieme that is not a real component of the machine but I only need to better organize the design, I imposed it as "hidden", just because in separate I don't care about the assieme but what it contains.
Hi, I just tried, but it only raises my first level, if there are more, it does not lead them to the first: Am I wrong? (obviously setting hidden) maybe in this mask should I set more paramentaries besides the hidden?
you have to put (from the lens-shaped icon..) setting to --> structured --> properties. --> all levels.
here it expands all the branches of the "genealogical" tree of your assembly .. great-grandparents, grandparents, fathers, children, grandchildren, grandchildren, bis-bis, etc.:smile:
I've already set it but nothing, or better it shows me all the levels, but I want all the sublevels to be brought to the first
you must have all the parts set, in " distinct only parts ", as " normal " also those nested.
I saw that it works if I put the under assemblies on "hidden", so apologize if I break again, but having long gone with all the codes of the assemblies, as "normal", I should reopen to manina all the files together and set them on "hidden" or there is a way to do the whole in a single shot?
thanks to all for patience:wink:
I and stefanobruno both wrote correct things, with some difference.
I did a test with a set containing subaxes and parts at various levels, first putting everything on "normal" and then all subaxes on "hidden".
in both cases, in "only parts" I will have all the parts brought to the first level;
in the distinct "structured", in the first case, I will not have the parts contained in a subaxieme; while in the second case I will see all the parts brought to the first level.
Yes, I've tried more than anything, now I understand.
thank you very much to all for explanations and patience
Hello everyone
