help sliding surfaces
  • Thread starter Thread starter frencisis
frencisis
Save to all I am here today xkè I have 1 problem with the surfaces:premitting that nn I used them very much I would like to know if it is possible to create a jar that leaves having the rectangular base and make it finish that it has the mouth to ellipse, surely there is the way but nn iresco to understand how to do, I tried to create 2 sketches 1 rectangular and the other on 1 other parallel elliptical plane and I have taken the sway . .
to do what you want, you don't need the slide protusion unless you want to indicate a bear to follow.
to you enough what on the st is called "savasatura" but that on 20 maybe had another name, I do not remember. if you use this feature works, I just tried.
p.s., what's the point of calling it devasation? Mah!
So I have solid edge version 17 exactly what are the procedures I should do 1 flies made my sketches? Thank you.
you have to search on the 17th the command you place (the name may be different I do not remember, but the symbol is that).
Then do the two sketches as you said and you'll see it goes.
thanks x the help but I managed in 1 other way: since my jar inside had to be hollow I used the bluesufr command first selecting the base of the solid future and then selecting the mouth of the jar in this way he generated me 1 solid vacuum inside then with 1 protusion I created the bottom closing it...I explained hoping to be of future help x someone with my same problem. x ki needed the command that explained leso in solid edge 17 is called "loft protection"
