help together with variable measures
  • Thread starter Thread starter papi22
papi22
hi to all I have a problem that I can't solve, I practically created 2 profiles and put them in a set and you can change the size of a profile and automatically the other profile also changes?
I hope you can help me in advance
Yes. change the share of one and if the other is linked to this (with variables, with equations, with references... In short, how do you prefer) fits accordingly
thank you for the answer,it's exactly what I can't do
Do you know if there is a guide to this?
I hope you will understand that not knowing your knowledge of the program, what you have to do and how and in what context you have to do it, adding with your lacunous explanation of the problem you cannot venture in indications of a method that has to cover a wide range of use.
there are the internal tutorials to the program, including the use of references and equations
