help toptron and
Cristian B
hello to all my name is cristian and I have a request to make you; I just started working and I would need help, to use toptron and 6.0
I've never seen my boss.
we have projects already completed by pro/e and we should pass them to toptron and then send them to the machine to run them.
Would someone be so kind to help me??
Thank you so much in advance.
If by "machine" you mean a miller, then you have to work in the cam environment, try to post something because, depending on the complexity of the piece, you can take ten minutes or two hours.
as a car I mean a frieze yes; as for the projects unfortunately I can't post anything to you, my boss keeps everything in a hdd that every day attacks on the pc and the evening breaks it (long story to tell)!
we should produce molds of automotive components in most;(e.g. brake discs,pinze,cilindri,pistons etc.)
Sorry I can't be clearer.
bhè very depends on the toptron package you have purchased (and 6.0 is a little dated.....). toptron theoretical online can import all the most common files, .igs by default, but depends on the licenses you have.
to process the cam paths to be sent to the milling machine you must have the specific post processor for the machine language of the milling in question.
