Heuto mesh hypermish
  • Thread starter Thread starter nicola1985
nicola1985
I'm new to the program.
I read some tutorials here and there but when I try to do something I can never...
For example amount the iges, I try to extract the midsurface and there are many missing parts!
I have to make an impact simulation using radioss.
Is there anyone who can lead me?
as version I have hyperworks 9.
Thank you all!
boys also go well links or files in English...the important thing is that they are well done!
I made mesh.
created the material.
constraints and forces.
I have only one problem. how to make him realize that the force is not static but is impulsive?
I have to think about a mesh to create a symmetrical mesh.
I figured out how to reflect what I didn't understand is how I pair the mesh...
Thank you!
I reflexed and copied the mesh but how do I copy the knots?
some pious soul that help me? ?
Thank you!
Bye. I'm sorry. are new to the forum and the first weapons with hypermesh.
I need to copy, both mirroring and rotating, solid geometry and mesh 3d together, to create a new component. My problem is that I can't copy (with "organizes") into a new component mesh and solid together but I can only copy them individually. In this way, while copying solid and mesh3d in the same new component, I do not have + a link between the two... then, for example, after I can no longer select the elements using the "by geom" selection, using surfaces/solids, because the mesh-solid connection is missing, which has not been copied.
I hope I've been clear. Unfortunately, I have to take advantage of symmetry, now I'm stuck. thanks for the help
hello to all, I am a new user, I challenge open discussion to put my problem on running a mesh on hypermesh software: I make mesh 2d on box-shaped containers with the automesh toggle function and it's okay. I do it on a cylinder and the program is stacked and leaves obvious holes in the surfaces.. someone can enlighten me.. Thank you.
Staff online
