hide the expressions of suppression
  • Thread starter Thread starter walterwhite
walterwhite
Hello everyone,
these days I am trying to hide the expressions of suppression of one or more features, or at least block access, so that others do not reproduce my models. Can you help me?
the procedure I use is to create a feature and suppress it through the command "sopprims by expression".
Thank you for your attention.
Hello everyone,
I can't understand what you want to do, I usually use the sopprimi by expression to get, for example, two incompatible jobs with each other. for their evaluation I put a conditional variable for which if this is worth 1 puts to 0 the expression of one feature and to 1 the other, or if it is worth 2 places to 1 the first and to 0 the second.
However, you don't see the feature.
If you want to show someone else a parametric model by hiding the features, I suggest you do this:
create the file with all your features, create an empty file and upload the first file as a component in the second, make the wave of this model, save and then give the second file without the first. you will find so with a 'freeze' model that you can 'refresh' when you want to reload the first.
