highlight pieces within an assembly
  • Thread starter Thread starter Tekkasoft
Tekkasoft
Hello, girl.
do you know how to highlight (or if you prefer to hide the rest) in a set, in the same way that the "active" command operates on a component?
that semi-transparent grey is possible to obtain it with some command in order to highlight, not only one component (com happens with the active command), but more components together?
I choose the model in the tree or window and then
#representation
or alternatively icons.
hinges
if I choose from the tree a component and follow the commands as described arni1 does not occur what I asked (to give some commands in sequence is not difficult...) but it only changes the representation of that object, while the rest remains as it is. What's the part of the command I can't use?
