historic building with archicad.
  • Thread starter Thread starter epasinet
are still incasin*to with complex profiles. for the windows I found various alternatives and good or bad I solved but for the rose window and the main door I don't know how to do. above all the door that is an element even more visible and large.
for lateral frames use complex profiles and polygonal walls.
for the arch you realize it with complex profiles as if it were horizontal, and with appropriately dimensioned ceilings the door and then save the 3d as object>port and insert it in the masonry
Now I try. but for complex profiles I am not succeeding in giving the thickness that I want and cmq to draw them correctly would serve a base (but I should do it in another file, right?). some basic notions on these complex profiles give me?
thanks for availability
no nessul external file. open the profile manager, draw the profile to lines and nets, apply the materials and associate it to the wall, column or beam
