Sp4rk0
good morning to all, I am early and I am 38 years old, first I worked in the automation industry, now I changed work and moved to heavy carpentry, but I have little knowledge regarding laser cutting or plasma cutting.
I explain to you the question specifically, I have a plate 300x350 sp.30, and it has holes from ø22, asking here at work they told me that for that thickness the plates cut them to the plasma, and the holes then make them to machine because the plasma cannot make holes of that size.
I wanted to understand one thing, regarding the cutting of sheet with holes, there is a general rule to calculate the diameter of holes that you can make on a plate, according to the thickness of the same?
Moreover, until the thickness of the sheet is cut with the laser, and from which thickness is cut to the plasma?
I hope I explained, thank you in advance
