holes with series function
  • Thread starter Thread starter ias87
ias87
hello to all.....I made a series of holes arranged in circumference.....if now I want to repeat them in radius circumferences via greater as I do using the serious function? ? ?
Wasn't it better to do the opposite? first the series of quota or direction and after that of the axis?
or a two-way series of the same hole :
make a hole, not linear but quoted with angle,
and then make a series where in the first directions change the corner,
and in the second change the radius or diameter of positioning.
simpler and lighter than series..... .
If I didn't get it wrong, with the axis series in two directions you should solve.
Bye.
