hood fireplace
  • Thread starter Thread starter Devis
Devis
Good morning to all, I sent the design of a hood, with the measures of my need, with a shelf of support. how can you see it is not designed properly, because you edges and some details you see are not the maximum, how can I perform these gaps to succeed and make a dxf for laser cutting so that it is finished well?? Thank you devis
It would be the case that you placed the model rather than the table without references. from what I see, there are interferences between bodies and flanges at 45° not entirely in combo. the tricks to take are different but to be more precise you should look at the tree of history.
In fact.
Always remember that to send the swx drawings you must always attach the model 3d of origin. as for the assemblies it is necessary to attach all the 3d parts that make them. otherwise the views are empty (clear, the references, the "fathers" remain on your computer).
this you can view with the Quick view, but it is practically useless because it is not minimally editable.. and then to answer your questions you need the model.
Mar
I sent you all the files together hoping that you can understand how to give me the right tips, maybe if you can give me an example with a small design, so I can understand better. Thank you.
Good morning, is there anyone who took a look at my set? Do you have any suggestions for the correct execution of this project? Thank you.
