hopper development
  • Thread starter Thread starter SweptBlend
SweptBlend
I have a problem with sheetmetal,
I created a hopper, attached,
transformation into sheetmetal,
(through shell option ),
wf2 creates surfaces with
variable gaussian curvature (undevelopable perks)
there is some sheet metal, which has confidence with the instrument,
that can enlighten me of immense?
(wf2/3/4/5 and also 6 is fine.... )
thanks in advance
hi swept, should be shaped differently.
the side surfaces are not flat and therefore are not developable in sheet-metal.
If I have time between today and tomorrow, I will see to find a tip.
In fact, by doing the Gaussian analysis of the part, it is seen that the surfaces that create the sheetmetal to create the sheet metal, are wintered. . . .
and then after they are undevelopable,
I think you have to create triangular fold for triangular fold,
but there is to die,
bhe, this is doublesimmetric, if you could make 1 quarter,
but how do sheet metals do?
Why don't you leave the sheet?
you can directly use the "mixed base" and see what happens
I used the technique to divide the piece and then mirror it, and it worked.
However, I think it is from the sheet metal environment.
Sorry, but it's been a while.
try to cut it and see if you can first pass through the sheet and second develop it.
