hopper from rectangular to circular sheet
  • Thread starter Thread starter strudeldemele
strudeldemele
Good morning to all
do you know how to make on sw2017 a sheet metal hopper (and then with development x production) that go from rectangular to circular profile?
on inventor there is a command but on sw it comes to mind only the loft......
Do you have any better ideas? ? ?
Thank you very much for the kind answer
Thanks I tried but with the rays and thicknesses I need it crashes.... Do you know what relationship exists between them? I have to pass from a rectangle sp1.5 r inside 1.5 from 326x99 to a circle ø180
but it succeeds only if I change the radius of the rectangle to 5mm; and that's exactly what I have to hold to 1.5 or max 2/2.5
for me all these figures say nothing.
how many times has it been said to put pictures and possibly the file?
the fold radius should not be drawn in the rectangle sketch, but it is set in the parameters of the sheet.
there is no relationship between thickness and radius that vary according to the bending equipment.
hi, I also went from inventor to solidworks I came across this problem, then I found this file (in attachment).
It's more and more complicated than inventor, but at least it looks more like a fitting. .
Try to see if it's useful.
hello to all
thanks for the advice... I managed to get a great result with a rectangle to circle loft where both have a small opening (sheet cut) and must have the same number of sides (very important)
look at this video....https://www.youtube.com/watch?v=wei9veexlu4
Good morning to all
I have a complete lesson, for example quoted, to perform and track the development and subsequent folds of the hopper.. clear designs and complete explanations. all handmade without programs but with maximum precision.
