hopper
  • Thread starter Thread starter novizio
novizio
Hello, excuse me I realize that this is a topic treated + times but I need a comfort/help! ! ! !
I am trying to draw this hopper (Annex dwg.rar hopper) I suggest that the design I will have to produce for constructions are for external workshops so I did not change factor k.
I have attached a set (tramoggia.rar) like the two side plates and the front sheet now I don't know where to start for the back one.
but my:confused: they are:
Is drawing it in sheet mode correct?
how can I have the flanges made to close on all sides as I schematized in the dwg? ?
ps: use iv 10
I ordered the judge of the pruners but that 2009 can I use this with iv 10? ? ?
thank you and excuse:finger:
I would do as for the front sheet only that you do not project the shape but the profile of the sheet you need and then add the upper and front flanges. to understand us drawings the sketch of the profile on a plane parallel to the direction of sliding of the tape and passing through the median line of the hopper.
drawing in sheet metal is correct, otherwise the development does not find it automatically.
Bye!
80-90% of the things on 2009 are also valid for version 10, of course there are new functions that you cannot use, but the "risk" however is that you will learn more things, not less...
thanks to all of you as soon as I have some time I try your advice (now I have to continue working with autocad)
The sin book arrived that the examples of the attached CD can only be opened with the 2009 version!!!!
