horizontal cutoff offset
  • Thread starter Thread starter matteocasali
matteocasali
I kindly wanted to ask if someone knows if it is possible to set the horizontal crop offset value of sections at project level or if it can be set only in the instance property palette. of a section.
Thank you in advance.
if you go to any plant where the section line is visible, you will also find (after selection of the same) a symbol with a double arrow that flows in normal direction than the section. that is the grip of the cut offset
