horizontal/vertical "linear" diameters
  • Thread starter Thread starter k.j.16
k.j.16
I'm making a table and I'm inserting in the 2d a quota over a diameter.
when I change its display using the "show as linear" command then I can no longer rotate it to put it horizontal or vertical.
In practice I can no longer do what with the old pro-e was going to look for the intersection on the reference lines of the quota.
this among other things happens only with the odds added in the 2d, with those of the 3d just make button dx and "change attack".
Hello and thank you so much!
Hello.
select the quota with the left mouse button and the "shift" pressed.
