how to adjust the detail of the sections?
  • Thread starter Thread starter epasinet
epasinet
I tried to create a section of a project through the use of the special command "section".
basically, with the active section tool, I tracked a plant line to indicate the section plan and so I automatically created the desired section.
the problem is that by trying to print this section in the classic 1:100 scale the doors and locks appear too detailed and therefore rich in too close lines. I noticed that trying to print a plant, archicad adapts the detail of doors and windows according to the chosen print scale, in fact printing the plant at 100 doors and windows are simplified to avoid weighting lines the print itself. printing the plant at 50 instead the doors and windows are automatically set with a higher representation detail and suitable for the scale.
do you think there is the possibility to manage the detail of representation even in the sections?
Bye. the sections in archicad are not 2d, but 3d. then in the parameters go on options (where there is scale sensitive), 3d or 3d views (not remember) and simple indirect instead of detailed
