MARCOO
good morning to all, excuse me for the trivial question, building the extrusion as a figure settles the finite dimensions and the dimensions that will then be understood of the sheet thickness. This means that in the end the measures established initially in the extrusion are not respected but in some cases will be added by the sheet thickness (e.g. the measures 20 become 20+ thicker) .
Do you know if there is a method of redefining extrusion quotas after giving the thickness?
Thank you very much
Thank you very much
