how to create a road
  • Thread starter Thread starter kubbah
kubbah
Hello
I would like to ask you experts how you would make a way with revit
I have to draw a floor plan, with a road system (tot roads about 2 km)
of course they want to represent with a planimetric view of the whole (classic view)
and also renderings.. .
What commands do I want to use?
how would you realize it?
create a planimetry (with the various elevation points) extended throughout the surface and then draw the lanes with sub-regions putting the asphalt material.
ok, then I will have to have the flat planimetry, with roads, dotted lines in the center etc... will be redesigned, won't it?
Another problem is that if I do so, and the planes are very incilined, the section of the road will also have an inclination towards the road section. . .
looks like the solution mile is a floor-made road with last adaptable layer
but then when I change the heights of the floor for points, they all create triangles to different inclination
to not show those lines "inside" but only those on the edge of the pavement is there a way?
having always in mind the display of a standard layout, in 2d
and then 3d packs, without having to make 2 separate models. .
the slope lines (of the triangles) cannot be erased.
did you try to make the roads with solids by extrusions/unions on path?
