how to create and write paper
  • Thread starter Thread starter SimoneViglianti
SimoneViglianti
Good evening boys,
are simone and I would like to ask your help to create and fill out the cartilage of a mechanical technical design.
Can anyone help me?
thanks in advance.
simone viglianti
if you are a student and you have the drawing book and/or a drawing manual as well as the norms uni m1 is written to us everything. What do you want to know about specifics? Your question suggests that you don't know what we're talking about, but then what did you do at school?
in mechanical there are by default, open someone and look how it is done. I assume that the software you know how to use it otherwise use normal autocad that has everything you need for a student
I tried the default but it doesn't meet my needs.
then I created one of my staff that I can use in all drawings.
My question was simple to have advice.
Before I ask you the question I studied the regulations and know what I'm talking about and how to build a paper mill.
My question was simply addressed to someone who wanted to give me advice.
if you have already created it, if you know the regulations and your question is
I would like to ask for your help to create and fill out the cartilage of a mechanical technical design.
Can anyone help me?
There's a foul somewhere. definitely missing the specification of the request of the help; per creation presupposes that it was not done. from here the answers received.
then if the default ones are not good for your needs we know? or maybe that part in your first post missed me?
help and advice are different concepts.
a practical cartiglio does not have much information, a rectangle with the data of the designer or company, a great field for the design code, a description of the piece, scale, taken, European projection system, angle for quantity, pane for general tolerances and unquoted bevels, box for general roughness and not, material delay and thermal treatments.
all this in 230 mm wide for a variable height but I would say crooked at 40/50 mm. is universal and also for the assemblies can be recycled, adding the table of the components.
other things that you can add are date, revision, directions for welds, son size, number of sheets, other useful indications in companies but not in all.
I work in a company where I fingerprinted this cartouche, I don't know if it can help you.
Good evening, guys.
I exempt this old discussion. in the writing of the data of the cartiglio such as project name, design number, etc.. is there a conventional text/great character used?
No.
character that is clear and does not have letters or ambiguous numbers such as zero and o.
