how to create tabs with vector
  • Thread starter Thread starter giacomo sciacca
hi sorry I wanted to know how the boards work as you can connect to the electronic sheet as you can connect to a project I wanted to know if there is a tutorial where you explain everything or examples thanks let me know
depends on what you need. In the sense that, the card creates it when you need to configure an electronic sheet ad hoc. for example, you need to keep a certain number of elements under control, maybe symbols and some of their features: name, size, surfaces, quantity... or have a cartilage with editable fields. once you create a tab, with the fields you need, select the object to be connected and from the info card, in the date tab, connect it to the specific tab.
to get the electronic sheet, go to the command "crea abaco or list". in the window that opens you will find the list of tabs contained in your project and you can select what interests you.
you can find tutorials on the youtube channel of vectorworks, doing a search for "record format". but also the software help can help you.
Good morning to all, and the first time I write on this forum but I can't solve a problem at which even the support of vectorworks managed to give me a clear solution. I hope that we can find new ideas here to solve the problem.
I have created custom tabs (record) in which to enter specific data type product code number, availability number at warehouse etc. data however to be compiled only once. from resource management then I collect the tab to the fixture and edit the symbol then fill the fields that interest me. the problem I have is this:
if I insert the object, dragging into the drawing as a symbol, the tabloid remains. if instead active (double click) the object from resource management and then insert it in the design as apoarecchio of lighting the tab and its data disappear!
How can I do that?
Thank you in advance.
