how to discreetly print a three-dimensional design?
  • Thread starter Thread starter Veronic87
Veronic87
Good morning to all,
I am new in this site and I hope to write in the right section, as I have searched a lot in the forums to look for an answer to my "simple" and perhaps trivial question, relative precisely to a simple print (with simple printer or better with pdf) that I can not do in decent quality (that is without the objects being constituted from 20-30 pixell at the most!). This only happens to me when I mold a design created in three-dimensional, so I don't understand where the problem is. if I make a drawing2d and then I prepare a layout where I recall the model, mold everything and in excellent quality, as well as I visualize the objects on the screen of the pc. with the drawings I create in three-dimensional (of simple objects among other things, because not to the first weapons with the 3d!) then I go to print (both on printer and on pdf as I said) and the print is horrible, the objects are printed in bad quality!
Somebody help me by chance?
Thank you!:wink:
Maybe you have a low-level graphics card. however first installs a pdf printer and then prints the 3d model. there will be some configuration makes set up for sure.
What program do you use? certainly not solidworks. did you try to make the isometric table with colored skin and print that?
hi, I would like to reopen this discussion, wondering how can I do to print well with solidworks, since after drawing from the top, when I go to print with pdf creator, the lines come badly, especially for 3d views. thanks in advance
remove the view in quality draft on the table and you will see that you solve.
if you need to do pdf do not print it but save it by name as pdf
I have already tried to do so, the result remains of low quality, so that the pdf file only weighs 250 kb, and the oblique lines are broken. So I ask, what is the best way to print in high quality with solidworks 2016? and then, it is not possible to print as with autocad in a vector way?
