Kaji
save sometimes I happen that importing step the generated solid is failed as to generate face parts; to avoid subsequent problems in the loading of good standard I try to delete the useless parts and keep the external ones for the encumbrances etc repairing them, with the various commands copy faces, eliminate faces, insert faces.
the thing that gives me more problems happens when I eliminate a face but I remain a suspended edge that there is no way to eliminate; It also happens to you, there is a lisp or something to eliminate these edges, also because the specific command eliminates edges I did not find it and when I delete 3d eliminates the parts and eliminates faces obviously eliminates me only the faces.
thanks for the availability and possible answers.
