how to enlarge multidirector too small
reggio
Hello, I have never used the multidirector (pallining) and I realize now that,
Unlike the odds that I can adapt in size with the dimscale command that in fact enlarges or decreases the quota size, and arrow, has no effect on the multidirector that remains of the same size either as number or letter as arrow ... :confused:
is there any way to adapt the multidirector?
Maybe with a directional command?
There is the multi-director toolbar that as well as that of the permeated odds to create the styles of the multi-director.
the command is mleaderstylecreate or change a style
in the second tab below there is the scale (see image) of the equivalent quota to the suitable quota style
otherwise the direct command is mleaderscale
changes little quickly if you create multidirector styles within the model you use.
styles give the possibility to change with a few clicks all the directions that have that precise style.
We put for example that you start to quota in scale 1:5, for some reason you have to pass to scale 1:10; instead of selecting all the directors with that scale (maybe you have other ones with different scale) and changing the property you just need to change the style feature and you are fine.
or use the direction with the arrow to insert the bubbles, but suddenly the arrow passes by fashion and you want to have the square ball; instead of selecting the bubble direction (maybe you have other ones for the working notes) change the style feature and you are fine.
However I don't want to sell you a method, it's just to do the pignolinoinculo and say my opinion on the two systems
