reggio
hi, I would like to succeed in exporting on excel the distinct sheet to be divided by thickness + obtain the maximum external size of the developed piece.
in the past I had tried with the pdm without getting anything, now I was thinking about trying with swx,
I see that it's information that sw has, and so, I think, it might return to me separately, but I didn't understand how to do it.
would you be able to guide me to insert the value of the sheet thickness distinct materials?besides the thickness I see that there is also the box item which indicates the virtual container of the part/lamiera,
the box value is indicated whether the sheet is saved as folded, whether saved as developed:
in my specific case I would like to get the sheet box developed (one of the 3 sizes will be identical to the thickness and the other two will be the one that interests me or lxh)
the problem at this point is that I can neither save all the sheets as developed because together lose all the links and makes confusion, both because I should open every sheet and save it developed by hand (then repeat the operation to put it back bent).
Do you know a better system to get the sheet box developed in distinct materials?
