lukino92
ok... I saw that this forum is very complicated
There's everything... and there's a thousand sections... so I certainly have wrong section to post. . .
I ask the moderators for forgiveness. . .
I wanted to ask you a lot of things, starting from simple banalita to advice and suggestions. . .
I am a student and I attend the technical institute for geometries... This is now the 4th year...
at first I used for 2 years the program progress, as always I think that here no one knows it, it goes well now are 2 years ke use autocad, lately 2009... I find it really well... in drawing 2d I think he's pretty good. I did anke a part of a course, which this year I will conclude forces, on the correct use of autocad, puttroppo is not recognized... Well, I've had a lot of... Now I got tired of drawing in 2d on autocad... and I started self-taught modeling and using autocad 2009 in 3d... That's why I found myself on this forum... First I would like to know if there are tutors guides to apprender and quickly and easily use 3d?!? ! ?
In addition I would like to ask you a question... I created a wall, and in this wall there are two openings... a door and a window... I did the work in a very barbaric way... I created the wall in pieces and mounted them.. .
I don't think he does anything like that. in fact I saw ke there are the tools emptied intersection and etc... But I can't find out how they work... Would you like to know how to make these openings in the wall?!? ! ?
in progress you could create the solid negatvo but here on we resco... I repeat I learned all alone 3d modeling...
I apologize for the rude way I exposed the problem and hoped in your help.. .
