how to mirror everything while keeping readable quotas and texts
reggio
Hello everyone,
we sometimes produce similar or identical machines only with the position of a component on the opposite side,
the solution adopted, for the spare parts boards is to not redesign/clonate everything and change the particular and/or recalculate everything, but
the old and mirrored table is taken, after which one must mirror, one by one, each ball, note and comment (only the quotas, from good they mirror themselves) ... a job for nothing pleasant and short.
Do you know a system that allows you to have readable texts after mirroring?
How would you do that?
hello "reggio", did you try to edit the variable "mirrtext" ?
enigma
I didn't know him...
mirrtext=0 solves:d
only the stuff stuck inside the carts, but it solves by turning only the drawing
Great! Thank you.
... just the stuff stuck inside the carts, but it solves by turning only the drawing...
Note that: inside the blocks, if the texts replace them by attributes (command _attdef) , they are mirrored following the mirrtext settings
