tatyb295
good morning, when I do a pdf print from the model space the designs are never printed properly, since at the time when I go to measure with the ruler on the printed sheet the measurements are not accurate. what settings do I need to insert? as a measuring unit I use the meters. if for example I have to print in scale 1:200 and I have already scaled the drawing in that scale and inserted inside a sheet a4 (always drawn on the model space) click on print, then dwg to pdf and as settings in the scale window what should I insert (where there are mm and units)?
