AlessioOvo
who knows how to quote folded pipes with a tide of different angles and folds or knows some text or manual explaining how to do it?
and for the views? I am forced to insert 5 views of which 2 in assonometry because if not I can not indicate the distance between one fold and the other that are on different planes and this part I want it to lean on the plane to do it in orthogonal projection. only that in doing so I get 5 seen how I have to place the views p.o, p.f, p.l, and the other two views can I put them where I want on the sheet? I have to indicate with arrows from where I look at the piece to make it clear to those who have to do it as a move? Then I have to write to us also how I rotated the view to make the part that I'm interested in quotating?if how do you indicate these options?inner diameter of the tube (or external) and thickness. or indicate the nominal diameter and nominal pressure to standard. then bend angles and inner fold radius.
