Alex97 Guest Jan 31, 2024 #1 I probably put this setting and you see this screen as I do to remove it.https://i.postimg.cc/d31bt9h1/selezione.jpgThank you.
Tristan Guest Feb 1, 2024 #5 https://www.autodesk.it/support/tec...n-window-that-are-attached-to-the-cursor.html
Alex97 Guest Feb 3, 2024 #6 thanks to the answer of tristan. I also ask there is a way to set the selection with a mouse click of lines placed in various positions of the drawing without holding down the capital key on the keyboard? Thank you.
Alex97 Guest Feb 5, 2024 #8 dsw said: the variable pickadd should be what you are looking for link Click to expand... Thanks for the help I put variable 2 and I set up.
