Stefano150687
Good morning, everyone.
use autocad 2009
I have a doubt with the corners, I explain
You have to make a tilted line at 31.20. How do I do that?
I do straight line, wheel command
Here comes the first doubt I have to write 31.20 or 31.20.
second doubt, I'm going to check the quota with the command angle. in both cases tells me that the line is tilted by 31st.
20' do you consider them or not?
use quotas 3 decimal quotas after the comma.
Do I have to turn the ranks? (I don't remember this)
Thank you very much
use autocad 2009
Thank you very much
