how to save pdf in more than a4 format with autocad mac
Silvia_Sds
hello to all I have a problem regarding pdf saving of a cad file. I have a printer installed on my mac, so at the time I open the print screen it proposes me as formats only those available with my printer (so a4 or lower). instead on another mac on which I have not installed any printer allows me to set as a3 or lower format.
How do I save pdf in larger formats?
obviously recognizes as a default printer that physics that can print only in 4a, to print in pdf you need a virtual printer, for example through the pdf creator or analog program, at that point you can select all the formats you need
In fact. the default printer is the one that said law. to do well you have to install a virtual pdf printer that arrives up to a0
theoretically it is not necessary to install any virtual printer (I theoretically say because on my it is not necessary but never known) because mac os x already manages the pdf on its behalf.
It's enough to do as Tristan said. set a custom sheet and then print the drawing from the pdf button on the bottom left in the print window.
If it doesn't work then try installing a virtual printer.
