how to scale section labels
  • Thread starter Thread starter CAROLINA
CAROLINA
Please tell me how I can reduce section labels in scale at 200 and 500.
I stuck the plants of my project in scale at 200 and then at 500 with highlighted sections, but the symbols at the ends are really too large.
I'd be very grateful. .
thanks and a thousand
carolina
carolina
I've seen it, but the problem is I can't... .
because editing the section does not give me the possibility to change the family also if you edit the section and go into the "type properties" "section label" opens the window with these editable parameters:
"extreme section" which in my case is "fresh"
"section symbol" which in my case is always "cold"
Broken display style in which it is indicated "continuous", but there is no reference to the size of the symbol so that it can be reduced.
Also in the families of revit I find not only the symbol probably is part of the template I used.. . .
Help!
Moreover, the section symbol used is the arrow where the section no is indicated and the reference of the table in which the section is inserted.
thank you dear
What do you mean by you know how to change a family??? ? Usually when you edit a family in the bar at the top you see the family change command and clicking here opens the family so that you can change it, but in this case no.... they are really a disaster... .
My question was rhetoric obviously. ...
....from the project browser expand the tree structure and look for the voice "families", then go to the subcategory " annotation symbols" and look for the family "cold". When you found it, click on it with the right button above and choose "change"
I add an additional info to what is said by tristan... When you change the family... I recommend "save by name"!
