luciafor
Good morning, I just signed up. I'm a neophyte.
This is the question. in the autocad model space I designed the organization of a table that must contain more designs.
practically the printing will happen on a sheet a0 so I made a rectangle of 1189x841 and I continued to divide the sheet using measures in mm.
the problem that is rising to me is that in different sections of this a0 will go different designs in different scales ( 1:100 / 1:50 / 1:5 )
How do I keep drawing?
for example:
line of 1 m and 25 cm. for scale at 1:100 do: 125cm/100=1,25cm and then type 12.5mm?
the same thing for the scale to 50 and then for a line of 1.25m type 25mm?
will I then simply print 1:1?
in autocad is set "current view annotation scale 1:1"
for example:
