how to take the correct quotation
  • Thread starter Thread starter stefer
stefer
Good morning, everyone. I happen sometimes to have a piece with a corner that at the end of processing then is rounded.
drawing, when I come to quote the rounded part, in truth I would often need to take the quota of the line that if it were unrounded would continue "for its way".
I realize it's probably stupid, but I can't figure it out.
I attach an image to be clearer. the only system I found is to put a construction line and to quote the intersection... but I wonder if there is something more elegant and immediate.
Thank you all!
sure...if you don't want to do another point you can always see the sketch of the part.. .1716985096605.webpI always do: select lines and point then intersection
when you're in the quota mode, if you right click on one of the two edges you have to quote, a menu opens where you can select the "find intersection" item. do the same for the other side and the share will leave you from their intersection.
