how to use roland dxy1300 plotter with autocad
  • Thread starter Thread starter Mimmo2020
Mimmo2020
Hello, to all of the forum, I need your help, I press that I am not very practical of autocad, then the point is this I would need to use the plotter to print on copper circuits printed for electronics. I have seen and read some tutorials that I can directly load a pdf design, but the problem arises when I go to print it!!! the plotter prints only the contours of the drawing I can not understand why. attached the file.
Thank you very much
cè pdf e pdf your is a pdf raster, i.e. like any photo or scan, probably your plotter wants vector pdfs that are the drawings that are printed in pdf directly from the cad programs, to make a similarity you have ever happened to open a pdf and succeed in selrzionare all the text or part? and other pdf where you can't select anything, had the same principle with word printing in virtual or scanning a document
thanks liber then I should transform the pdf or any other image into vector and feed it into dxf to autocad.why I did this bringing the file to dxf but print the same only contours. ?
