how to verify if a solid has been emptied
  • Thread starter Thread starter Big
Big
after emptying a known cylinder that if I do not click above with the mouse, I do not see any result as from image qui.
question, do you think the solid is really emptied?
as you modeled it you were emptied inside, as if it were a sealed jar.
if you want to get the effect of a tube you have to delete the caps
thanks joseph and lattu for your answers.
from what you tell me, it seemed to me to understand that it is not possible directly with the command empty having an effect of a tube; I've never managed this command until now. to have the tube effect I usually fill in the command _ presspull as from image qui.
if this is possible even with the empty command I will remain waiting for your further clarifications, thank you.
it is possible with boolean (you will take a cylinder, a smaller cylinder) or by extruding a region equal to the section of your tube
.....if this is possible also with the empty command I will remain waiting for your further clarifications, thank you.
command: modifsolidiautomatic control solid modification: solidcheck=1
type a solid editing option [Faccia/SPigolo/Corpo/Annulla/eSci]<esci>: </esci>ctype a body editing option[Impronta/sePara solidi/SVuota/eLimina/Controlla/Annulla/eSci] <esci>: </esci>svSelect a 3d solid: Selectremove faces or [Annulla/AGgiungi/TUTTE]: 1 face found, 1 removed. (Selected the first face)remove faces or [Annulla/AGgiungi/TUTTE]: 1 face found, 1 removed. (Selected the second face)remove faces or [Annulla/AGgiungi/TUTTE]:indigotype the offset distance of the emptying: 10Solid validation initiated.
Solid validation completed.
type a body editing option[Impronta/sePara solidi/SVuota/eLimina/Controlla/Annulla/eSci] <esci>:</esci>indigoautomatic control solid modification: solidcheck=1
type a solid editing option [Faccia/SPigolo/Corpo/Annulla/eSci]<esci>:</esci>indigo
Okay, thanks for the alternatives, so confirm that directly with emptying is not possible? or better, if that were possible, then I should erase the caps... What I wouldn't know after how to do.
Excuse me. gp, as rightly pointed out in the post above, the procedure you made is the same as I did before; this however previews an emptying solo all'interno, instead I would like to get a result like "tubo" with the command empty (always if it is possible to do so).
Last thing, using the mode-solid command doesn't give me the chance to select the second face... from f2 comes this:
command:
changes
type a solid editing option [Faccia/SPigolo/Corpo/Annulla/eSci]<esci>: c
type a body editing option</esci>[Impronta/sePara solidi/SVuota/eLimina/Controlla/Annulla/eSci] <esci>:
Select a 3d solid:
remove faces or </esci>[Annulla/AGgiungi/TUTTE]: sending
type a body editing option[Impronta/sePara solidi/SVuota/eLimina/Controlla/Annulla/eSci] <esci>: sending</esci>
... the procedure you have made It's the same as I did before; but this provides for an emptying solo all'interno, instead I would like to get a result like "tubo"
is not the same, you at the request "Remove faces or [Annulla/AGgiungi/TUTTE]:" you pressed forward, without selecting the faces to remove and exclude from emptying, look well the procedure I posted.
to the request select the upper face of the cylinder, then rotate the view in order to see the face below (shift+rotellina) and the selections.. .
you are fully right!!! I found that it was enough to select the first face, rotate the view, select the second face, and here is the game is done. My compliments, Mr. Gp!
