how to view drawings in .dwf
  • Thread starter Thread starter Giovannino60
try with dwfattach in autocad otherwise with dwf viewer, you should already have installed it
in autocad you can not open them, you can only insert them, as already said guyver.
to view them, without inserting them in autocad, there is autodesk design review that you install with autocad if you chose it during installation.
if you have not installed it, you can download it for free from the autodesk site, it is free.
I installed it at the end a message comes out to end the installation the computer must be restarted, I restarted is output again a screen that asked me to run it seems to me the same exe, I tried to click and it seemed to me that it was reinstalling the same program I interrupted, but now the dwfs by clicking above do not, what do I have to do?
with viewer opens but I did not understand how to open it in autocad.
I think it's clear:
test with dwfattach in autocad otherwise with dwf viewer, you should already have installed it
in autocad non You can open them, you can only insert, as Guyver already told you.
