hydraulic cylinder test
  • Thread starter Thread starter ale72
ale72
good morning I should check if the attached image cylinder can lift the indicated weight. Can someone explain how to do this? Thank you.
Sorry you're right. the axieme is mounted on an agricultural equipment connected to a tractor.
I'm not sure of the tractor pump data but I believe around 100 lt/m and a pressure of about 150 bar. you work on the unfavorable side
Thank you
the distances between the centers of rotation, without it is not possible to make any account
those unfortunately I do not have them yet...we set at the distance from the center of weight and b the distance from the hole of the cylinder chamber
This is also a problem of reverse cinematics.
in previous threads I learned that dealing with the thing in a mathematical way causes a lot of dismay. .
I give you the most popular advice from other users: model the structure with a cad (when obviously you have the odds), use the dynamic module of the above cad to question the strength that the cylinder should generate and compare this force with what is really capable of generating, note the operating conditions .
