Coupè1988
Good evening to all,
I came across a thermo-hydraulic problem, the theme is not purely of oleodynamics or tire but not harming.
practically I would like to study a hydraulic network (cooling circuit of a car) and understand the flow of water in the various branches, and then then calculate the thermal exchanges in the various exchangers knowing the input and output temperatures.
the system is a dynamic system where there is a pump with a characteristic curve (prevalence in function of motor turns), with various fittings exchangers, widening and shrinking. Moreover at a certain temperature the thermostatic valve begins to open and I would like to know how the flow is divided between the various branches.
Have you ever come across these issues?
Is there a programme that can simulate this network?
