Joel
Sorry if I fill the forum, but I'm trying to learn how to use hypermesh and venedo from catia world - solidworks I find myself a little in trouble. doing the tutorial, important a caty file, I made the corrections of the surfaces (before they were in red).
1- When the "lines" are green means that they are correct, that is, there are no overlapping problems or "strap"? .
2- the lines in yellow what they indicate, can I leave it so in general or the best case is to correct it by erasing it and remake the surface?
3- when I corrected the surfaces, as I repeat coming from catia, at least in caia there was tangence with the adjacent surface (for surface correction) which I do not see in hypermesh. I wanted to know how I understand that the adjoining surface is tangent?
4 - a difficulty that I found (even banal) is in the creation of elementary geometries such as point, lines and itsprphics. for hypermesh the point and knot are the same thing?, to create a line you have to go from the knot?. is it possible to create lines, knots or points in parametric form? (as with catia and solidworks)
Thank you again and I apologize for the number questions I have asked today.
Joel
Joel
