joncad
even if I'm taking my hand with this new soft, there are still some things I can't fully understand.
I was following this simple tutorial:
http://www.5min.com/video/how-to-draw-in-autodesk-inventor-2011-299991107 It's for inventor 2011 I have the 2010 version but I think it does the same. At least I think.
I designed the sketch as indicated then I tried to move and center the center of the circle on the central point of the grid as indicated by the tutorial. in the tutorial manages without problems but to me it is prevented and an error message warns me:
"the addition of this bond will hyperwine the sketch"
I don't understand why. will it be because I started drawing the first line of the sketch right from the center of the grid or what?
with these hypervincles still quarrel.
Can you help me understand why and what should I do?
