i can't put x,y axes on the origin of the design.
  • Thread starter Thread starter Alex97
Alex97
I can't put x,y axes on the origin of the design. I click on the axes but I can't move the axes, with the mouse I move the axes but then they come back. I wrote on the command line ucs, clicked sending, I take with the mouse the axes put them on the drawing but then return to the bottom left. What can I do? Thank you.
I probably moved the axes into a design edge, see attached image, but it's not yet what I have to do to correctly bring the plant into a software for the modeling of the energy certification, as the software tells me that I did not model the file on the absolute origin 0 of the design, how can I do?
If I click zoom everything, the axes I see them left detached from the drawing. I counterbalanced even though there are dots of lines around the design.
to post the drawing in 0.0.0, I selected it>sposta>#>0>0, but the value that is in the cell takes the zero but by sending again a series of numbers as at the beginning and the design does not move.
if you write 0<0 means that you move 0 units to the right. Why don't you move... have you ever thought about taking a nice autocad course? These are the basics!
That's what I have. the sign> I have meso to make understand the seizure of the passages.. .
definitely is a "sporty" design with presence of entities dispersed in space and should be clean. Anyway... .
#0.0 only works if dynamic input is enabled (activable and deactivable with f12), if it is disabled, after switching the command, simply type 0.0
in a file clicking f12 does not change anything i.e. does not hear this command, what I can do.
if I try to manually move the axes, once clicked with the mouse the axes return to the position of origin qundi to the bottom left and do not remain in the desired position?
How do I proceed?
