i create 2 conflict problem together
  • Thread starter Thread starter nicolac
nicolac
I've got a bad thing.
I went to creo 2, I opened a set with creo 2 and closed without doing anything, now if I reuse I create 1 and shore to open the same together does not let me open it.... .
I can open the parts individually with creo 1, but not the same parts in assembly, these parts were bits or jaws that served to hold tight the piece to put in the machine, so it does from equipment for the cnc, then to ship to the manufacturing, I create 1 no longer open the manufacturing where it contained these bits with a scherc part call
to make it short, having opened with creo 2 a manufacturin that recalled an old starmodel with the command schearc part... I'm afraid he's changed something in the bites that he never let me open it again with Reo 1
they were bound with the flexibility of an excused quota but if one works with creo 2 and wants to pass the job to another who has created 1 , what should reassemble the axieme?
which is proe/creo can read the antecedent versions, but not vice versa. to make available to users with antecedent versions you have to provide it all in neutral format (*.neu). recently, and only for some versions, there should also be a program or something similar that translates into the various versions.
to reuse everything in the previous version, search in the library of start-parts those that have been modified by creo 2, delete them and everything will return as before.
I also made your own mistakes, now for every new wreck covers my main directories, libraries etc., I modify the config.pro and point the starting directory in order to keep the environments of the various versions divided. this food until I'm sure I can completely abandon the old man.
hoping for help
aminati
but you closed it without saving it and you checked the problem? or did you save him?
if it is worth the first, maybe at the first start creo2 has automatically updated some templates that then is used in opening all files, old and new....
yes with all complete packages simulated etc...no restriction, on the site of the ptc there is already and you can download
as in all versions of pro/e - I create until now released, when opening a file of any type made with a previous version and open with the last, if you do not save anything the file you can always open it with the previous one, idem is for the passage creo 1.0 towards creo 2.0, nothing has changed.
If with "I can't open them" you say that when you open it doesn't load and fail, it means that the search_path paths that load the components not in work directories are wrong, for this in combined mode does not make them open anymore, it testifies the fact that you individually the files can open them, then to 100 % the problem is in search_path.
